주요 콘텐츠로 건너뛰기
Hoover Windtunnel Air Steerable Upright Wheel Replacement
필요한 것
  1. Hoover Windtunnel Air Steerable Upright Wheel Replacement, Wheel: 1 단계, 이미지 1/1
    • Lay the vacuum flat on the ground, then flip it over 180 degrees so that you can see the inside of the wheel.
  2. Hoover Windtunnel Air Steerable Upright Wheel Replacement: 2 단계, 이미지 1/2 Hoover Windtunnel Air Steerable Upright Wheel Replacement: 2 단계, 이미지 2/2
    • Locate the small metal pin and bolt holding the wheel in place.
  3. Hoover Windtunnel Air Steerable Upright Wheel Replacement: 3 단계, 이미지 1/1
    • Take the needle nose pliers and stick them in the rectangular hole.
    • With the pliers, firmly grasp the metal pin that holds the bolt for the wheel in place.
    • Slide the pin off the bolt by pushing the pliers forward.
    • Carefully remove the pin from the rectangular hole and keep it in a safe place.
  4. Hoover Windtunnel Air Steerable Upright Wheel Replacement: 4 단계, 이미지 1/1
    • Now, remove the wheel by pulling it away from the vacuum.
    • The bolt will come out with the wheel since the pin is gone.
결승점
Wyatt Cornelison
회원 가입일: 09/26/17
101 평판
안내서 1개 작성함
Cal Poly, Team S7-G2, Banghart Fall 2017 Cal Poly, Team S7-G2, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G2
5 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 14
전체 시간: 3,626
