소개
Hornady lock n load auto charge
Having issues with Motor not running
Inconsistent speeds/ jerking around.
install new IC to fix the issue
Clean Brushes on Motor
필요한 것
You can see the damage to the L298N
required a new Motor Controller IC. This happened loading 300 Cartridges back to back. Duty Cycle was to much. ADDED heat sink is a must if loading may Cartridges!!!
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Fantastic article. I have the identical complication but need a new board due to one of the internal wires being severed. I am unable to locate any source for the replacement of the board, plus no item number for ID on the board. Any help is greatly appreciated. Hornady has a Terrible Attitude and admits no faults. I had to return this unit for a warranty on the initial purchase due to a lack of calibration on the 50 side. Used it 4 times and it is DOA. It is never left on or with a power source connected.
My numbers 7,8,9,and unit buttons don't work I've tried looking for part to fix it but can't find anything on it
