이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Empty Powder out
Remove anything that will fall out when you turn it over to get to the 6 phillips screws in the botton
remove the 4 round foam feet to exposed the screws. unscrew the 6 screws
slowly separate the black bottom from the red top. there is a motor connecter, screen connector, and 2 connector for the keypad.
There is 1 circuit board and you can see the l298n on the right side. take circiut board out and unsoder the l298n. install New L298n with Heat sink . and reassemble.
You can see the damage to the L298N
required a new Motor Controller IC. This happened loading 300 Cartridges back to back. Duty Cycle was to much. ADDED heat sink is a must if loading may Cartridges!!!
when testing after new IC was installed
Motor would Jerk and was not smooth. disassemble motor and clean brushes.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Fantastic article. I have the identical complication but need a new board due to one of the internal wires being severed. I am unable to locate any source for the replacement of the board, plus no item number for ID on the board. Any help is greatly appreciated. Hornady has a Terrible Attitude and admits no faults. I had to return this unit for a warranty on the initial purchase due to a lack of calibration on the 50 side. Used it 4 times and it is DOA. It is never left on or with a power source connected.
My numbers 7,8,9,and unit buttons don't work I've tried looking for part to fix it but can't find anything on it
