소개
Use this guide to replace the electrical cord on the Hot Tools HPK12 Titanium Flat Iron.
The cord provides power to the flat iron. You will know if the device is working if the metal plates are hot when the cord is plugged in. Do not plug in a frayed or cracked cord.
Changing the electrical cord is a four-step process. Each step includes easy to follow instructions and a photo that demonstrates what you need to do.
Note that step three will require strength.
필요한 것
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Where can I get a replacement cord? You only show how to removed it but not how to fix it
