주요 콘텐츠로 건너뛰기
Hot Tools HPK12 Heating Plate Replacement
필요한 것
  1. Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: 1 단계, 이미지 1/3 Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: 1 단계, 이미지 2/3 Hot Tools HPK12 Heating Plate Replacement, Prerequisite Only: 1 단계, 이미지 3/3
    • Remove round plastic cover near cord base by prying under the side with the metal spudger.
    • Flip the device and remove the other round plastic cover near the base of the cord.
    • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
  2. Hot Tools HPK12 Heating Plate Replacement: 2 단계, 이미지 1/1
    • Use the metal spudger to push the center pin through to the other side.
  3. Hot Tools HPK12 Heating Plate Replacement: 3 단계, 이미지 1/2 Hot Tools HPK12 Heating Plate Replacement: 3 단계, 이미지 2/2
    • Lift back plastic cover to expose spring assembly.
    • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
    • Grip the exposed end of the spring assembly and remove it.
    • The side with the two ends of the spring goes into the recessed area of the iron
  4. Hot Tools HPK12 Heating Plate Replacement: 4 단계, 이미지 1/1
    • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
  5. Hot Tools HPK12 Heating Plate Replacement: 5 단계, 이미지 1/3 Hot Tools HPK12 Heating Plate Replacement: 5 단계, 이미지 2/3 Hot Tools HPK12 Heating Plate Replacement: 5 단계, 이미지 3/3
    • Lift upward on the control assembly cover to remove it from the flat iron base.
    • Remove dial and switch cover and set aside.
  6. Hot Tools HPK12 Heating Plate Replacement: 6 단계, 이미지 1/3 Hot Tools HPK12 Heating Plate Replacement: 6 단계, 이미지 2/3 Hot Tools HPK12 Heating Plate Replacement: 6 단계, 이미지 3/3
    • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
    • Lift the backing plate upwards to remove it from the flat iron.
    • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
  7. Hot Tools HPK12 Heating Plate Replacement, Heating Plates: 7 단계, 이미지 1/1
    • Lift plate and circuit assembly away from flat iron case.
  8. Hot Tools HPK12 Heating Plate Replacement: 8 단계, 이미지 1/1
    • Flip device to access the non-control assembly flat iron arm and remove two 3.5mm “J0” screws that attaches cover to flat iron base.
  9. Hot Tools HPK12 Heating Plate Replacement: 9 단계, 이미지 1/1
    • Lift cover from flat iron case.
  10. Hot Tools HPK12 Heating Plate Replacement: 10 단계, 이미지 1/2 Hot Tools HPK12 Heating Plate Replacement: 10 단계, 이미지 2/2
    • Lift heating plate away from flat iron case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathan Schwartz
회원 가입일: 10/24/16
318 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-4, Baechle Fall 2016 IUPUI, Team 3-4, Baechle Fall 2016 회원
IUPUI-BAECHLE-F16S3G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 882
