주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hot Tools Professional 1110 Disassembly
필요한 것
  1. Hot Tools Professional 1110 Disassembly, Hot Tools Professional 1110 Disassembly: 1 단계, 이미지 1개 중 1개
    • Ensure that you have a clean work station, and that you can easily keep track of small, loose parts.
    • In addition, MAKE SURE IT IS UNPLUGGED FOR ALL FOLLOWING STEPS!
  2. Hot Tools Professional 1110 Disassembly: 2 단계, 이미지 2개 중 1개 Hot Tools Professional 1110 Disassembly: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Firmly grasp the end of the Iron with the black plastic cap on the heating element end.
    • With your free hand, use tweezers to firmly grasp the small retaining ring sitting between the heating element and the handle body.
    • Once you have a firm grasp, pull up on the retaining ring, and it should come loose.
  3. Hot Tools Professional 1110 Disassembly: 3 단계, 이미지 1개 중 1개
    • With the ring loose, turn the handle body over, and you will see three screw holes.
    • Take a PH1 screwdriver, and loosen up all three 6mm Phillips #1 screws in the handle body.
  4. Hot Tools Professional 1110 Disassembly: 4 단계, 이미지 1개 중 1개
    • Once the screws have been removed, set them aside and with a pry tool, firmly pull the handle body apart in half lengthwise.
  5. Hot Tools Professional 1110 Disassembly: 5 단계, 이미지 2개 중 1개 Hot Tools Professional 1110 Disassembly: 5 단계, 이미지 2개 중 2개
    • For removing the clamping mechanism, firmly grasp the iron in your hand by the handle body, and locate the screw as shown in the picture.
    • Remove the screw shown (8mm Phillips #2 Pan Head) and when finished do the same for the opposite side.
  6. Hot Tools Professional 1110 Disassembly: 6 단계, 이미지 1개 중 1개
    • Once both screws have been removed, continue to remove the top clamping half of the mechanism from the body of the Iron.
  7. Hot Tools Professional 1110 Disassembly: 7 단계, 이미지 1개 중 1개
    • Rotate the handle, and remove the screw that holds on the spring mechanism for the clamp. This screw is a 8mm Phillips #2 Pan Head.
    • Once this step is fished your Hot Tools Professional 1110 will be fully disassembled and ready to have its components replaced.
결론
작성자
3다른 기여자 명과 함께
Sean Neal
회원 가입일: 11/11/17
101 평판
안내서 1개를 작성함
IUPUI, Team S2-G2, Wilson Fall 2017 IUPUI, Team S2-G2, Wilson Fall 2017 회원
IUPUI-WILSON-F17S2G2
4 회원들
안내서 5개를 작성함
3가이드 댓글
How can I tighten the clamp?
Sharon Gonzalez - 답글
where can i get or order the part for the (spring with small roller)
i have a model ht1110xl hot tools iron
Fred Medina - 답글
What is the c/b that acts as the on/off switch? It was improperly shrink wrapped causing it to burn through and break the switch
Kim P. - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 73
전체 시간: 4,756
