소개
Over time and repeated use the temperature control feature may become defective on most curling irons. This guide provides step-by-step instructions on how to replace the temperature control switch. Temperature controllers consist of input-output systems. A type of input sensor and signal is needed depending on the controlled process. Outputs are used to control the process of heating and cooling. This guide does not offer instructions on how to replace individual components of the temperature control system. Replacement of the temperature control switch only is described here.
필요한 것
Ensure that you have a clean work station, and that you can easily keep track of small, loose parts.
In addition, MAKE SURE IT IS UNPLUGGED FOR ALL FOLLOWING STEPS!
이 단계에 사용된 도구:Tweezers$4.99
Firmly grasp the end of the Iron with the black plastic cap on the heating element end.
With your free hand, use tweezers to firmly grasp the small retaining ring sitting between the heating element and the handle body.
Once you have a firm grasp, pull up on the retaining ring, and it should come loose.
