소개
The target user for the tool is a professional who uses a heat for forming and bending a variety of materials.
필요한 것
All screws on one side for ease of assembly
Wire has a stiffener for protection
Switch is placed on handle in an ergonomic position so that one hand operation is easy
The back of the handle and the back of the body are in a straight plane in order to place the gun in vertical position after operation to cool it down
Vents are placed in the top part to facilitate air flow
The product is colored in industrial orange to be easily visible and distinguishable from the work environment
All plastic detailing is made to have no overhangs
screwing details are used in order to locate the two half together without external jig
A lip joint is used in order to secure the assembly and also make it impermeable and rigid
All electrical components are connected using connectors instead of direct soldering to facilitate easy replacement
The components have negative placers inbuilt in the in plastic injection mold
The electrical components are placed in order to prevent shorting
All heat components are suspended in order to prevent the heated elements to come in contact with plastic parts
The blower chamber is designed in heat resistant pet in order to prevent it from deformation
The motor and the blower fan has a press fit
The heat tube is using mica support and kapton insulation
The external heat tube is stainless steel to prevent degradation of the tube.
The heat coil is used as a resistor to step down voltage for motor and hence it has a dual perpose
The heat coil is made of nichrome wire.
Minimum number of screws (variety) are used and all screws are self tapping in order to eliminate the use of nuts and loose parts.
Assembly has location pins to align circular parts in a fixed orientation.
Heat rings are used in order to over heating
댓글 한 개
Any idea where I can get a replacement for the plastic fan? It just fell off and melted and there doesn’t seem to be any information on the net. It’s a simple part. I’ve only used the gun a half a dozen times but it’s been years since it was purchased. Your instructions were helpful.
C Richards - 답글
