소개
This guide will walk you through replacing the battery in your Hott T725-8G.
필요한 것
Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
Remove the yellow tape holding the wire connecting the battery to the motherboard with your fingers.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
