주요 콘텐츠로 건너뛰기
Hott T725-8G Speaker Replacement
필요한 것
  1. Hott T725-8G Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Gently dislodge the speaker from the back panel so that it is only connected to the motherboard.
  2. Hott T725-8G Speaker Replacement: 2 단계, 이미지 1/1
    • You can check the connection point between the speaker and the motherboard to see if it is firmly connected (which it should be) using the plastic Spudger.
    • Detach the wires using the plastic Spudger to replace the speaker.
결론
Emma Carroll
회원 가입일: 10/20/16
193 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 6-2, Martin Fall 2016 UMass Dartmouth, Team 6-2, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G2
3 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 81
