주요 콘텐츠로 건너뛰기
Household Item AcuRite 02081M Observer Repair Replacement
  1. Household Item AcuRite 02081M Observer Repair Replacement, AcuRite 02081M Observer Repair: 1 단계, 이미지 1개 중 1개
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a plastic opening tool.
  2. Household Item AcuRite 02081M Observer Repair Replacement: 2 단계, 이미지 1개 중 1개
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
  3. Household Item AcuRite 02081M Observer Repair Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the 4 M2x1.5-7 screws (7mm length) from the green PCB board.
    • This will result in two pieces, the back black cover and the PCB board.
  4. Household Item AcuRite 02081M Observer Repair Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • The battery can then be popped out using precision tweezers and replaced with a new one.
결론
작성자
3다른 기여자 명과 함께
anhut51190
회원 가입일: 07/04/19
281 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 9
전체 시간: 215
