주요 콘텐츠로 건너뛰기
Household Primo water dispenser not charging
동영상 개요
  1. Household Primo water dispenser  not charging, Household Primo water dispenser  not charging: 1 단계, 이미지 1/3 Household Primo water dispenser  not charging, Household Primo water dispenser  not charging: 1 단계, 이미지 2/3 Household Primo water dispenser  not charging, Household Primo water dispenser  not charging: 1 단계, 이미지 3/3
    • Insert wisdom here.
결론
다른 3명이 해당 안내서를 완성하였습니다.
goasfaras youcansee
회원 가입일: 10/02/19
301 평판
안내서 3개 작성하였습니다
댓글 한 개
I wish I had found this video before I had bought this particular pump dispenser. On the other hand, maybe my son can actually fix it because he likes messing with things just like this. Thank you, goasfaras, for that very good video. It was very instructive. If you do any more in the future though, pay attention to your voice volume, the direction in which your voice is going, and the pitch of your voice. There were times during the video when I couldn't hear anything that you were saying and I had to guess. I'm hoping that I understood your message correctly in that you said there was no way to fix the pump without using better pieces than what was found on the little board.
Ted Cassetta - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 25
30일 전: 113
전체 시간: 5,183
