소개
In order to replace most parts in this saw, you will first need to remove this housing by unscrewing the nine screws located around the saw. If the housing is either broken or cracked. It can be easily replaced by following the steps below.
필요한 것
Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
