주요 콘텐츠로 건너뛰기
Hover 1 Eclipse Battery Replacement
  1. Hover 1 Eclipse Battery Replacement, Battery: 1 단계, 이미지 1/3 Hover 1 Eclipse Battery Replacement, Battery: 1 단계, 이미지 2/3 Hover 1 Eclipse Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the right side bottom shell piece.
  2. Hover 1 Eclipse Battery Replacement: 2 단계, 이미지 1/2 Hover 1 Eclipse Battery Replacement: 2 단계, 이미지 2/2
    • Locate the black and red wires connected by an yellow header, Xt60.
    • This wire connects the battery to the motherboard.
    • Carefully tug on the two sides of the yellow header to disconnect them.
  3. Hover 1 Eclipse Battery Replacement: 3 단계, 이미지 1/3 Hover 1 Eclipse Battery Replacement: 3 단계, 이미지 2/3 Hover 1 Eclipse Battery Replacement: 3 단계, 이미지 3/3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that secure the black plastic keeping the battery in place.
    • Carefully remove the black plastic from the hoverboard.
    • Be mindful of the wires surrounding the battery.
  4. Hover 1 Eclipse Battery Replacement: 4 단계, 이미지 1/2 Hover 1 Eclipse Battery Replacement: 4 단계, 이미지 2/2
    • Be careful with the wires surrounding the battery when executing this step.
    • The battery is attached to the metal with an adhesive.
    • Firmly grasp the battery and tug on it until it is free from the metal.
결론
Mina Dedijer
회원 가입일: 10/10/19
545 평판
안내서 4개 작성하였습니다
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019 회원
CPSU-REGAN-F19S12G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 27
전체 시간: 2,247
