주요 콘텐츠로 건너뛰기
Hover 1 Eclipse Bluetooth Speaker Replacement
필요한 것
  1. Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: 1 단계, 이미지 1/3 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: 1 단계, 이미지 2/3 Hover 1 Eclipse Bluetooth Speaker Replacement, Bluetooth Speaker: 1 단계, 이미지 3/3
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the plug side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the plug side bottom shell piece.
    • Remove the plug side bottom shell piece
  2. Hover 1 Eclipse Bluetooth Speaker Replacement: 2 단계, 이미지 1/3 Hover 1 Eclipse Bluetooth Speaker Replacement: 2 단계, 이미지 2/3 Hover 1 Eclipse Bluetooth Speaker Replacement: 2 단계, 이미지 3/3
    • within the plug side shell piece, there are two white and pink wires connecting the shell and the motherboard.
    • On the circuit board by the speaker, carefully squeeze and unplug the small white headers that connect the shell piece to the hoverboard body.
    • On the body of the board, follow the wires that connect the lights to the motherboard. Disconnect these wires from the motherboard by squeezing and pulling the small white headers.
    • Now you can fully remove the shell piece.
  3. Hover 1 Eclipse Bluetooth Speaker Replacement: 3 단계, 이미지 1/3 Hover 1 Eclipse Bluetooth Speaker Replacement: 3 단계, 이미지 2/3 Hover 1 Eclipse Bluetooth Speaker Replacement: 3 단계, 이미지 3/3
    • Using a Phillips #0 Screwdriver, remove the 3 screws holding the speaker to the shell.
    • Lift the speaker out from the casing.
결론
Mina Dedijer
회원 가입일: 10/10/19
545 평판
안내서 4개 작성하였습니다
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019 회원
CPSU-REGAN-F19S12G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 324
