주요 콘텐츠로 건너뛰기
Hover 1 Eclipse Charging Port Replacement
필요한 것
  1. Hover 1 Eclipse Charging Port Replacement, Charging Port: 1 단계, 이미지 2개 중 1개 Hover 1 Eclipse Charging Port Replacement, Charging Port: 1 단계, 이미지 2개 중 2개
    • Using a Phillips #1 Screwdriver, remove the four 11mm screws that surround the edge of the left side bottom shell piece.
    • Using a Phillips #1 Screwdriver, remove the four 13mm screws that surround the edge of the left side bottom shell piece.
    • The order and placement of the 2 types of screws is mirrored for both sides of the bottom shell.
    • Pull back and set aside the left bottom shell halve. This shell half is still wired to rest of the hoverboard.
  2. Hover 1 Eclipse Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew the ring around the inside section of the charging port.
  3. Hover 1 Eclipse Charging Port Replacement: 3 단계, 이미지 1개 중 1개
    • Follow the wire back from the charging port to where it plugs into the board.
    • Unplug the wire from the board, and pull it through the ring you previously unscrewed from the charging port.
  4. Hover 1 Eclipse Charging Port Replacement: 4 단계, 이미지 2개 중 1개 Hover 1 Eclipse Charging Port Replacement: 4 단계, 이미지 2개 중 2개
    • Pull the charging port and wire attached to it out through the front side of the port.
    • Take the plastic protector off of the charging port.
결론
작성자
3다른 기여자 명과 함께
Mina Dedijer
회원 가입일: 10/10/19
548 평판
안내서 4개를 작성함
Cal Poly, Team S12-G4, Regan Fall 2019 Cal Poly, Team S12-G4, Regan Fall 2019 회원
CPSU-REGAN-F19S12G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 13
전체 시간: 941
