주요 콘텐츠로 건너뛰기
Hover-1 Charger Outer Shell Replacement
필요한 것
  1. Hover-1 Charger Outer Shell Replacement, Outer Shell: 1 단계, 이미지 1/2 Hover-1 Charger Outer Shell Replacement, Outer Shell: 1 단계, 이미지 2/2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Outer Shell Replacement: 2 단계, 이미지 1/1
    • Pull the right cover away from the hoverboard.
  3. Hover-1 Charger Outer Shell Replacement: 3 단계, 이미지 1/2 Hover-1 Charger Outer Shell Replacement: 3 단계, 이미지 2/2
    • Unscrew four 12 mm screws that hold the right foot pad with a Philips #2 screwdriver.
    • Unscrew the four 18 mm screws with a Philips #2 screwdriver.
    • Use a long, thin screwdriver to access the two 12 mm screws nearest to the wheel.
  4. Hover-1 Charger Outer Shell Replacement: 4 단계, 이미지 1/2 Hover-1 Charger Outer Shell Replacement: 4 단계, 이미지 2/2
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
  5. Hover-1 Charger Outer Shell Replacement: 5 단계, 이미지 1/3 Hover-1 Charger Outer Shell Replacement: 5 단계, 이미지 2/3 Hover-1 Charger Outer Shell Replacement: 5 단계, 이미지 3/3
    • Unplug the black, yellow, green and red four pin connector from the circuit board.
    • Unplug the red and black two pin connector from the circuit board.
  6. Hover-1 Charger Outer Shell Replacement: 6 단계, 이미지 1/2 Hover-1 Charger Outer Shell Replacement: 6 단계, 이미지 2/2
    • Thread the black, yellow, green, and red four pin connector through the opening to the left of the battery.
    • Remove the right foot pad from the hoverboard.
  7. Hover-1 Charger Outer Shell Replacement: 7 단계, 이미지 1/1
    • Pull the left cover away from the hoverboard.
  8. Hover-1 Charger Outer Shell Replacement: 8 단계, 이미지 1/2 Hover-1 Charger Outer Shell Replacement: 8 단계, 이미지 2/2
    • Unplug the red and white five pin connector from the circuit board.
    • Thread this connector through the middle cylinder.
    • Remove the right cover from the hoverboard.
  9. Hover-1 Charger Outer Shell Replacement: 9 단계, 이미지 1/2 Hover-1 Charger Outer Shell Replacement: 9 단계, 이미지 2/2
    • Unplug the red and white four pin connector from the speaker circuit board.
    • Unplug the blue and white three pin connector.
    • Unplug the blue and white two pin connector. This is photographed as an example.
  10. Hover-1 Charger Outer Shell Replacement: 10 단계, 이미지 1/1
    • Remove the left cover from the hoverboard.
  11. Hover-1 Charger Outer Shell Replacement: 11 단계, 이미지 1/2 Hover-1 Charger Outer Shell Replacement: 11 단계, 이미지 2/2
    • Disconnect the two pronged black and yellow cable.
  12. Hover-1 Charger Outer Shell Replacement: 12 단계, 이미지 1/3 Hover-1 Charger Outer Shell Replacement: 12 단계, 이미지 2/3 Hover-1 Charger Outer Shell Replacement: 12 단계, 이미지 3/3
    • Remove three black and red two pin connectors from the left circuit board.
    • Remove the red, yellow, and black three pin connector.
    • Remove zip tie if present.
  13. Hover-1 Charger Outer Shell Replacement: 13 단계, 이미지 1/1
    • Unscrew four 12 mm screws from the sides holding the left foot pad with a Phillips #2 screwdriver.
    • Unscrew four 18 mm screws with a Phillips #2 screwdriver.
  14. Hover-1 Charger Outer Shell Replacement: 14 단계, 이미지 1/1
    • Remove the left foot pad from the hoverboard.
결론
Mark Rapiz
회원 가입일: 10/10/19
229 평판
안내서 1개 작성함
Cal Poly, Team S12-G1, Regan Fall 2019 Cal Poly, Team S12-G1, Regan Fall 2019 회원
CPSU-REGAN-F19S12G1
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Where do I buy the shell their website doesnt have it
firestineanthony - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 506
