소개
Learn how to replace the battery with this guide. Any power related problems may need a battery replacement. For this guide, you will need a Phillips #2 screwdriver and a metal spudger.
필요한 것
Flip the Hover-1 Chrome upside down.
Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
Place the metal spudger end between the blue battery and the adhesive pad that attaches it to the metal body.
Use the spudger to pry the battery loose from the adhesive.
다른 한 분이 해당 안내서를 완성하였습니다.
