주요 콘텐츠로 건너뛰기
Hover-1 Chrome Battery Replacement
필요한 것
  1. Hover-1 Chrome Battery Replacement, Hover-1 Chrome Disassembly: 1 단계, 이미지 1/1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Battery Replacement: 2 단계, 이미지 1/1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Battery Replacement: 3 단계, 이미지 1/2 Hover-1 Chrome Battery Replacement: 3 단계, 이미지 2/2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome Battery Replacement, Battery: 4 단계, 이미지 1/1
    • Place the metal spudger end between the blue battery and the adhesive pad that attaches it to the metal body.
    • Use the metal spudger only as a last resort if the adhesive is too strong for either your hands or other plastic prying tools.
    • Use the spudger to pry the battery loose from the adhesive.
  5. Hover-1 Chrome Battery Replacement: 5 단계, 이미지 1/2 Hover-1 Chrome Battery Replacement: 5 단계, 이미지 2/2
    • Pull and wiggle the battery completely off of the adhesive using your hands.
    • Remove the battery from the body.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nick McGuire
회원 가입일: 10/08/18
551 평판
안내서 4개 작성하였습니다
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018 회원
CPSU-WHITE-F18S4G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 15
전체 시간: 675
