주요 콘텐츠로 건너뛰기
Hover-1 Chrome Bluetooth Speaker Replacement
필요한 것
  1. Hover-1 Chrome Bluetooth Speaker Replacement, Bluetooth Speaker: 1 단계, 이미지 1/1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Bluetooth Speaker Replacement: 2 단계, 이미지 1/1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Bluetooth Speaker Replacement: 3 단계, 이미지 1/1
    • Lift the shell with the speaker grille so the speaker can be accessed.
    • Remove the three 14 mm Phillips #2 screws holding the speaker to the bottom left shell.
  4. Hover-1 Chrome Bluetooth Speaker Replacement: 4 단계, 이미지 1/3 Hover-1 Chrome Bluetooth Speaker Replacement: 4 단계, 이미지 2/3 Hover-1 Chrome Bluetooth Speaker Replacement: 4 단계, 이미지 3/3
    • Pull off the bracket holding the speaker in place.
    • Place the speaker to the side so that the tab on the cable connector to the sound card can be accessed.
  5. Hover-1 Chrome Bluetooth Speaker Replacement: 5 단계, 이미지 1/2 Hover-1 Chrome Bluetooth Speaker Replacement: 5 단계, 이미지 2/2
    • Disconnect the cable attaching the speaker to the sound card.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nick McGuire
회원 가입일: 10/08/18
551 평판
안내서 4개 작성하였습니다
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018 회원
CPSU-WHITE-F18S4G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 641
