주요 콘텐츠로 건너뛰기
Hover-1 Chrome LED Headlights Replacement
필요한 것
  1. Hover-1 Chrome LED Headlights Replacement, Hover-1 Chrome Disassembly: 1 단계, 이미지 1/1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome LED Headlights Replacement: 2 단계, 이미지 1/1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome LED Headlights Replacement: 3 단계, 이미지 1/2 Hover-1 Chrome LED Headlights Replacement: 3 단계, 이미지 2/2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome LED Headlights Replacement, LED Headlights: 4 단계, 이미지 1/3 Hover-1 Chrome LED Headlights Replacement, LED Headlights: 4 단계, 이미지 2/3 Hover-1 Chrome LED Headlights Replacement, LED Headlights: 4 단계, 이미지 3/3
    • Use a Phillips #2 screwdriver to remove the two 2 mm screws on either side of the LEDs.
    • Remove the LED board.
    • The LEDs are not symmetrical. This step is for the right side of the board, next to the power button. The left side is covered next.
  5. Hover-1 Chrome LED Headlights Replacement: 5 단계, 이미지 1/2 Hover-1 Chrome LED Headlights Replacement: 5 단계, 이미지 2/2
    • Locate the LED headlights on the left side of the board.
    • Pull the red wire attached to the LEDs perpendicular to the other wires to disconnect it.
  6. Hover-1 Chrome LED Headlights Replacement: 6 단계, 이미지 1/3 Hover-1 Chrome LED Headlights Replacement: 6 단계, 이미지 2/3 Hover-1 Chrome LED Headlights Replacement: 6 단계, 이미지 3/3
결론
Nick McGuire
회원 가입일: 10/08/18
551 평판
안내서 4개 작성하였습니다
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018 회원
CPSU-WHITE-F18S4G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 191
