주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 Chrome Left Gyroscope Sensor Board Replacement
필요한 것
  1. Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Hover-1 Chrome Disassembly: 1 단계, 이미지 1개 중 1개
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
    댓글 쓰기
  2. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 2 단계, 이미지 1개 중 1개
    • Lift the shell without the speaker grille and unplug the battery.
    댓글 쓰기
  3. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 3 단계, 이미지 2개 중 1개 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
    댓글 쓰기
  4. Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: 4 단계, 이미지 3개 중 1개 Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: 4 단계, 이미지 3개 중 2개 Hover-1 Chrome Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: 4 단계, 이미지 3개 중 3개
    • Disconnect the speaker cable.
    • Disconnect the cable that travels to the other sensor board.
    댓글 쓰기
  5. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 5 단계, 이미지 3개 중 1개 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 5 단계, 이미지 3개 중 2개 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 5 단계, 이미지 3개 중 3개
    • Disconnect the smaller connector midway on the cable.
    • Disconnect the larger connector midway on the cable.
    댓글 쓰기
  6. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four 12mm Phillips #2 screws securing the sensor board.
    댓글 쓰기
  7. Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 7 단계, 이미지 2개 중 1개 Hover-1 Chrome Left Gyroscope Sensor Board Replacement: 7 단계, 이미지 2개 중 2개
    • Locate the five solder locations on the underside of the gyroscope sensor board.
    • Plug in soldering iron and wait for the tip tip to reach its target temperature.
    • Rest the tip of the iron on the solder and wait for the solder to melt. The wire will drop out of the sensor board.
    • Be aware of where the tip of the soldering iron is at ALL times. Put on safety glasses before picking up the soldering iron. Turn on a fan and face it towards the device to vent harmful fumes away from the solderers face.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Nick McGuire
회원 가입일: 10/08/18
551 평판
안내서 4개를 작성함
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018 회원
CPSU-WHITE-F18S4G1
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 28
전체 시간: 1,547
