주요 콘텐츠로 건너뛰기
Hover-1 Chrome Outer Shell Replacement
필요한 것
  1. Hover-1 Chrome Outer Shell Replacement, Hover-1 Chrome Disassembly: 1 단계, 이미지 1/1
    • Flip the Hover-1 Chrome upside down.
    • Use a Phillips #2 screwdriver to remove the fourteen 14 mm screws from the bottom of the Hover-1.
    • Break the two black tape circles, and remove the two 15 mm Phillips screws underneath.
  2. Hover-1 Chrome Outer Shell Replacement: 2 단계, 이미지 1/1
    • Lift the shell without the speaker grille and unplug the battery.
  3. Hover-1 Chrome Outer Shell Replacement: 3 단계, 이미지 1/2 Hover-1 Chrome Outer Shell Replacement: 3 단계, 이미지 2/2
    • Lift the shell with the speaker grille.
    • Unplug the speaker.
    • Unplug the LEDs.
    • Unplug the power button
    • Unplug the charging port.
  4. Hover-1 Chrome Outer Shell Replacement, Outer Shell: 4 단계, 이미지 1/1
    • Remove the twelve 14 mm Phillips #2 screws holding the top shell on.
    • The other six screws are on the side without the battery.
  5. Hover-1 Chrome Outer Shell Replacement: 5 단계, 이미지 1/3 Hover-1 Chrome Outer Shell Replacement: 5 단계, 이미지 2/3 Hover-1 Chrome Outer Shell Replacement: 5 단계, 이미지 3/3
    • Free the cables held atop the bracket holding the battery in place.
    • Remove the four 14 mm Phillips #2 screws holding the battery bracket in place.
    • Pull the battery bracket free.
  6. Hover-1 Chrome Outer Shell Replacement: 6 단계, 이미지 1/1
    • Unplug the cords for the top LEDs.
    • The other side of the board is structurally symmetrical. However instead of going under the battery bracket, these cords go through a zip tie. These cables must be removed from the zip tie in order to continue.
  7. Hover-1 Chrome Outer Shell Replacement: 7 단계, 이미지 1/1
    • Turn the board over and pull the top panel off.
결승점
Dylan Prins
회원 가입일: 10/08/18
212 평판
안내서 1개 작성함
Cal Poly, Team S4-G1, White Fall 2018 Cal Poly, Team S4-G1, White Fall 2018 회원
CPSU-WHITE-F18S4G1
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Where can i get a replacement shell?
born4roblox - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 12
전체 시간: 326
