주요 콘텐츠로 건너뛰기
Hover-1 Coast Board Battery Replacement
필요한 것
  1. Hover-1 Coast Board Battery Replacement, Board Battery: 1 단계, 이미지 1/3 Hover-1 Coast Board Battery Replacement, Board Battery: 1 단계, 이미지 2/3 Hover-1 Coast Board Battery Replacement, Board Battery: 1 단계, 이미지 3/3
    • To remove the battery on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using a pick tool, puncture the grip tape and expose the screws.
    • Loosen all four 1" screws using a Phillips #1 screwdriver.
  2. Hover-1 Coast Board Battery Replacement: 2 단계, 이미지 1/3 Hover-1 Coast Board Battery Replacement: 2 단계, 이미지 2/3 Hover-1 Coast Board Battery Replacement: 2 단계, 이미지 3/3
    • Now pull the black protective cover off the board.
    • Locate the battery.
  3. Hover-1 Coast Board Battery Replacement: 3 단계, 이미지 1/3 Hover-1 Coast Board Battery Replacement: 3 단계, 이미지 2/3 Hover-1 Coast Board Battery Replacement: 3 단계, 이미지 3/3
    • The battery is connected by these two sets of wires.
    • Remove the yellow wire first by pulling the two wires gently in opposite directions.
    • Now pull apart the black wire by gently pulling the two wires in opposite directions.
  4. Hover-1 Coast Board Battery Replacement: 4 단계, 이미지 1/3 Hover-1 Coast Board Battery Replacement: 4 단계, 이미지 2/3 Hover-1 Coast Board Battery Replacement: 4 단계, 이미지 3/3
    • Once the battery has been disconnected, gently pry the battery upward.
    • It is important to use a plastic opening tool to avoid puncturing the battery.
    • Once the battery is freed, remove it with your hands.
    • The battery is glued to the case and will require some effort to remove.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jace Oppenlander
회원 가입일: 10/04/18
545 평판
안내서 4개 작성하였습니다
댓글 한 개
Where can you order a replacement battery?
Phil - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 639
