주요 콘텐츠로 건너뛰기
Hover-1 Coast Trucks Replacement
필요한 것
  1. Hover-1 Coast Trucks Replacement, Trucks: 1 단계, 이미지 1/3 Hover-1 Coast Trucks Replacement, Trucks: 1 단계, 이미지 2/3 Hover-1 Coast Trucks Replacement, Trucks: 1 단계, 이미지 3/3
    • In order to remove the trucks on the Hover-1 Coast, you must uncover the screws on the top of the board.
    • Using the pick tool to puncture the grip tape and reveal the screws.
    • The board should look like this.
  2. Hover-1 Coast Trucks Replacement: 2 단계, 이미지 1/3 Hover-1 Coast Trucks Replacement: 2 단계, 이미지 2/3 Hover-1 Coast Trucks Replacement: 2 단계, 이미지 3/3
    • Once all four screws have been revealed, locate the socket wrench and the Phillips #1 screwdriver in the wrench handle.
    • Place the 9/16 inch socket wrench over the nut; place the the Phillips #1 screwdriver in the screw.
    • Hold the socket wrench in place and twist the screwdriver counterclockwise to loosen the nuts.
  3. Hover-1 Coast Trucks Replacement: 3 단계, 이미지 1/3 Hover-1 Coast Trucks Replacement: 3 단계, 이미지 2/3 Hover-1 Coast Trucks Replacement: 3 단계, 이미지 3/3
    • Remove the nuts from the bottom of the board.
    • Slide the unwanted trucks off the screws.
    • The black rubber spacer will stay on the board.
결론
Alaina Limon
회원 가입일: 10/04/18
97 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 236
