주요 콘텐츠로 건너뛰기
Hover-1 Folding E-Scooter Brake Switch Replacement
필요한 것
  1. Hover-1 Folding E-Scooter Brake Switch Replacement, Brake Switch: 1 단계, 이미지 1/1
    • Twist the handle with the red level counterclockwise to remove it from the scooter's main body.
    • You will need to twist the handle clockwise reattach it to the scooter's main body.
  2. Hover-1 Folding E-Scooter Brake Switch Replacement: 2 단계, 이미지 1/2 Hover-1 Folding E-Scooter Brake Switch Replacement: 2 단계, 이미지 2/2
    • Remove the four 5 mm screws twisting counterclockwise with a Phillips #0 screwdriver.
    • These screws are small and easy to lose.
    • When inserting for reassembly the screws twist clockwise to secure.
  3. Hover-1 Folding E-Scooter Brake Switch Replacement: 3 단계, 이미지 1/3 Hover-1 Folding E-Scooter Brake Switch Replacement: 3 단계, 이미지 2/3 Hover-1 Folding E-Scooter Brake Switch Replacement: 3 단계, 이미지 3/3
    • Remove the red brake switch by sliding it off the main body.
    • When putting the brake switch back make sure to align the tab with the throttle switch.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brittani Kealoha
회원 가입일: 10/08/18
251 평판
안내서 1개 작성함
Cal Poly, Team S15-G5, White Fall 2018 Cal Poly, Team S15-G5, White Fall 2018 회원
CPSU-WHITE-F18S15G5
4 회원들
안내서 5개 작성하였습니다
댓글 6개
Do you know where I can find just the handle? They sent me a L and R but the L was stripped and won't screw in and the R will screw into both sides so I need either a L or R at this point I don't care i just can't find one and its “out of warranty”
Angela Renteria - 답글
Hi, I’m looking for a Hover-1 Eagle left handle?  Do you where can I find it? Thanks
Keila Talarico - 답글
looking for a new brake switch a hover-1 scooter,my grandson crashed and broke the brake switch. please help
Neal Weeks - 답글
Looking new break switch.where we will get?. please reply.
Vitesh - 답글
Looking for a throttle switch. Know where I can find one?
Mara - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 27
전체 시간: 4,619
