이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide is designed to help you replace a broken or damaged brake switch. All you will need is a #0 and #2 Phillips screwdriver to remove the screws in this guide
필요한 것
Twist the handle with the red level counterclockwise to remove it from the scooter's main body.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 6개
Do you know where I can find just the handle? They sent me a L and R but the L was stripped and won't screw in and the R will screw into both sides so I need either a L or R at this point I don't care i just can't find one and its “out of warranty”
Hi, I’m looking for a Hover-1 Eagle left handle? Do you where can I find it? Thanks
looking for a new brake switch a hover-1 scooter,my grandson crashed and broke the brake switch. please help
Neal Weeks - 답글
