소개
Is your deck on your Hover-1 Folding eScooter damaged? If so here is a guide to help you replace it with a new one.
필요한 것
Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
Remove the two 25mm screws by twisting a Phillips #2 screwdriver counterclockwise.
Hold the two 10mm nuts in place with a 10mm wrench.
Remove the two 33mm bolts connected to the 10 mm nuts by turning a hex 4.0 screwdriver counterclockwise.
To reassemble your device, follow these instructions in reverse order and use the new deck instead.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
The latch does not operate properly and is missing a part on the right side so it cannot retract the steel bar that locks the position. What part do I need and can you pls send it? It’s a brand new unit.
step 7 is where mine is broken .. it was kicked hard and right after the 2 screws but before the curb has been snapped what do i do
