주요 콘텐츠로 건너뛰기
Hover-1 Folding E-Scooter Rear Wheel Replacement
필요한 것
  1. Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: 1 단계, 이미지 1/2 Hover-1 Folding E-Scooter Rear Wheel Replacement, Rear Wheel: 1 단계, 이미지 2/2
    • Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
    • The two screws are the same thread so find the screw that has the least torque. Only that screw will be able to removed in this step.
    • Turn the hex bit 4.0 counterclockwise to reassemble the axle screws.
  2. Hover-1 Folding E-Scooter Rear Wheel Replacement: 2 단계, 이미지 1/3 Hover-1 Folding E-Scooter Rear Wheel Replacement: 2 단계, 이미지 2/3 Hover-1 Folding E-Scooter Rear Wheel Replacement: 2 단계, 이미지 3/3
    • Slide off the plastic side panel.
  3. Hover-1 Folding E-Scooter Rear Wheel Replacement: 3 단계, 이미지 1/1
    • Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
    • You will need to hold the other screw you are not replacing with an additional hex bit 4.0, so that the screws don't spin freely.
  4. Hover-1 Folding E-Scooter Rear Wheel Replacement: 4 단계, 이미지 1/1
    • Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
  5. Hover-1 Folding E-Scooter Rear Wheel Replacement: 5 단계, 이미지 1/3 Hover-1 Folding E-Scooter Rear Wheel Replacement: 5 단계, 이미지 2/3 Hover-1 Folding E-Scooter Rear Wheel Replacement: 5 단계, 이미지 3/3
    • Slide off the other plastic side panel.
  6. Hover-1 Folding E-Scooter Rear Wheel Replacement: 6 단계, 이미지 1/1
    • On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
    • The axle pops out and the wheel easily comes off.
    • Two washers will pop out with the axle.
결론
Luke Imai
회원 가입일: 10/08/18
133 평판
안내서 1개 작성함
Cal Poly, Team S15-G5, White Fall 2018 Cal Poly, Team S15-G5, White Fall 2018 회원
CPSU-WHITE-F18S15G5
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Where can you get replacement rubber for the front and rear wheels?
jackricotta - 답글
How about adding a rear wheel removal article for the Hover-1 Alpha folding scooter?
sfaheysd - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 69
전체 시간: 5,309
