이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove either of the two 0.2 mm axle screws by using a hex bit 4.0 by turning clockwise.
Use a hex bit 4.0 to screw back in the 0.2 mm screw as tightly as possible by turning clockwise.
Flip over the scooter and use the hex bit 4.0 to remove the other 0.2 mm screw.
On the same side you removed the screw, use the bit extender to push down on the axle inside the wheel.
댓글 2개
Where can you get replacement rubber for the front and rear wheels?
