주요 콘텐츠로 건너뛰기
Hover-1 H1 Battery Replacement
필요한 것
  1. Hover-1 H1 Battery Replacement, Bottom Shell: 1 단계, 이미지 1/1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Battery Replacement: 2 단계, 이미지 1/1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Battery Replacement: 3 단계, 이미지 1/2 Hover-1 H1 Battery Replacement: 3 단계, 이미지 2/2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Battery Replacement: 4 단계, 이미지 1/1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Battery Replacement, Battery: 5 단계, 이미지 1/1
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  6. Hover-1 H1 Battery Replacement: 6 단계, 이미지 1/1
    • Gently lift the battery harness and remove the battery by lifting the battery and moving it away from the hoverboard.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Aaron Teh
회원 가입일: 10/08/18
442 평판
안내서 2개 작성하였습니다
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 회원
CPSU-WHITE-F18S17G6
4 회원들
안내서 7개 작성하였습니다
댓글 11개
The stickers were the trick. I didn’t see them!
Daniel D - 답글
After removing the 4 screws that is holding the battery in place I still can't remove the battery. I tried gently to pry under the battery but it doesn't budge. Uni Sun model HY-A01B. How do I solve this problem?
Terry Pollard - 답글
Where do I get another battery to replace it???
Tony Pate - 답글
That's the question I can't seem to find the answer to
Darin -
Very low quality. Bought for my son who haven’t even used it for 15 times. Got it during winter and before summer the product stopped working.
tosin3in1 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 38
30일 전: 185
전체 시간: 9,399
