주요 콘텐츠로 건너뛰기
Hover-1 H1 Charging Port Replacement
필요한 것
  1. Hover-1 H1 Charging Port Replacement, Bottom Shell: 1 단계, 이미지 1개 중 1개
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Charging Port Replacement: 3 단계, 이미지 2개 중 1개 Hover-1 H1 Charging Port Replacement: 3 단계, 이미지 2개 중 2개
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Charging Port Replacement: 4 단계, 이미지 1개 중 1개
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Charging Port Replacement, Charging Port: 5 단계, 이미지 2개 중 1개 Hover-1 H1 Charging Port Replacement, Charging Port: 5 단계, 이미지 2개 중 2개
    • Using a utility knife, scratch off the hot glue from the connector attaching the red and black wires to the motherboard.
    • Be careful to not damage the wires or connector when removing the glue.
  6. Hover-1 H1 Charging Port Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the charging port connector from the motherboard by squeezing the connector and pulling the connector up.
  7. Hover-1 H1 Charging Port Replacement: 7 단계, 이미지 2개 중 1개 Hover-1 H1 Charging Port Replacement: 7 단계, 이미지 2개 중 2개
    • Using an adjustable wrench, unscrew the nut that is attaching the charging port to the bottom shell.
    • It might be helpful to put the charger in the charging port while unscrewing the nut to ensure that the port is not spinning.
  8. Hover-1 H1 Charging Port Replacement: 8 단계, 이미지 2개 중 1개 Hover-1 H1 Charging Port Replacement: 8 단계, 이미지 2개 중 2개
    • Pull the charging port to the left through the shell.
결론
작성자
1다른 기여자 명과 함께
Madeline David
회원 가입일: 10/08/18
286 평판
안내서 2개를 작성함
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 회원
CPSU-WHITE-F18S17G6
4 회원들
안내서 9개를 작성함
2가이드 댓글
I need to replace the charging port on my H1 hoverboard. Can you share the link for the actual replacement part.
prdrngga - 답글
Who can I contact to fix this charging port on this H one hover one hover board
Hover1 h1 hoverboard - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 34
전체 시간: 4,623
