주요 콘텐츠로 건너뛰기
Hover-1 H1 Gyroscope Sensor Assemblies Replacement
필요한 것
  1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Bottom Shell: 1 단계, 이미지 1개 중 1개
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 2 단계, 이미지 1개 중 1개
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 3 단계, 이미지 2개 중 1개 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 3 단계, 이미지 2개 중 2개
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 4 단계, 이미지 1개 중 1개
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: 5 단계, 이미지 2개 중 1개 Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: 5 단계, 이미지 2개 중 2개
    • On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
  6. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 6 단계, 이미지 2개 중 1개 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  7. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 7 단계, 이미지 2개 중 1개 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  8. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the sensor assembly on the battery side of the hoverboard by gently lifting and pulling away from the hoverboard.
  9. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 9 단계, 이미지 3개 중 1개 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 9 단계, 이미지 3개 중 2개 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the hot glue holding in the connectors with a utility knife.
    • Remove the white cable from the sensor assembly by squeezing the connector and pulling the connector up.
    • Be careful not to touch any parts of the circuit boards with the knife.
  10. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the red, blue, and green cable from the extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  11. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 11 단계, 이미지 2개 중 1개 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up.
  12. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 12 단계, 이미지 2개 중 1개 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 12 단계, 이미지 2개 중 2개
  13. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the sensor assembly on the motherboard side of the hoverboard by gently lifting and pulling away from the hoverboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Aaron Teh
회원 가입일: 10/08/18
442 평판
안내서 2개를 작성함
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 회원
CPSU-WHITE-F18S17G6
4 회원들
안내서 9개를 작성함
1가이드 댓글
where can I get the replacement parts?
Rob Sayles - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 25
전체 시간: 6,429
