주요 콘텐츠로 건너뛰기
Hover-1 H1 LED Headlight Replacement
필요한 것
  1. Hover-1 H1 LED Headlight Replacement, Bottom Shell: 1 단계, 이미지 1/1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 LED Headlight Replacement: 2 단계, 이미지 1/1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 LED Headlight Replacement: 3 단계, 이미지 1/2 Hover-1 H1 LED Headlight Replacement: 3 단계, 이미지 2/2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 LED Headlight Replacement: 4 단계, 이미지 1/1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 LED Headlight Replacement, LED Headlights: 5 단계, 이미지 1/1
    • Unplug the lights from the battery by pulling gently on both sides of the black connector attached to the white wires.
  6. Hover-1 H1 LED Headlight Replacement: 6 단계, 이미지 1/1
    • Remove the vertical light from the shell by using your hands to pull it free from the surrounding shell.
  7. Hover-1 H1 LED Headlight Replacement: 7 단계, 이미지 1/1
    • Remove two 8mm screws using a Phillips #0 screwdriver to rotate the screws counterclockwise.
    • Remove the horizontal light by using your fingers to pull the light up out of the shell.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sara Passantino
회원 가입일: 10/08/18
347 평판
안내서 2개 작성하였습니다
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 회원
CPSU-WHITE-F18S17G6
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 18
전체 시간: 1,346
