주요 콘텐츠로 건너뛰기
Hover-1 H1 Gyroscope Sensor Assemblies Replacement
필요한 것
  1. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Bottom Shell: 1 단계, 이미지 1/1
    • Remove the ten 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
    • Remove the twelve 9mm sheet metal screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  2. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 2 단계, 이미지 1/1
    • Puncture the two black stickers by using the tip of a screwdriver.
    • Remove the two 9mm machine screws by using a long Phillips #2 screwdriver to rotate the screws counterclockwise.
  3. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 3 단계, 이미지 1/2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 3 단계, 이미지 2/2
    • Lift each side of the bottom shell by pulling up.
    • When lifting the shell, take care to not tear any cables from their connectors.
  4. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 4 단계, 이미지 1/1
    • Unplug the battery by pulling gently on both sides of the orange connector.
  5. Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: 5 단계, 이미지 1/2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement, Gyroscope Sensor Assemblies: 5 단계, 이미지 2/2
    • On the battery side of the hoverboard, remove the red, black, and purple sleeved cable from the sensor assembly by squeezing the tab and pulling up.
  6. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 6 단계, 이미지 1/2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 6 단계, 이미지 2/2
    • Remove the red, blue, and green cable from the cable extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  7. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 7 단계, 이미지 1/2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 7 단계, 이미지 2/2
    • Remove the four 7mm screws by using a Phillips #2 screwdriver to rotate the screws counterclockwise.
  8. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 8 단계, 이미지 1/1
    • Remove the sensor assembly on the battery side of the hoverboard by gently lifting and pulling away from the hoverboard.
  9. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 9 단계, 이미지 1/3 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 9 단계, 이미지 2/3 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 9 단계, 이미지 3/3
    • Remove the hot glue holding in the connectors with a utility knife.
    • Remove the white cable from the sensor assembly by squeezing the connector and pulling the connector up.
    • Be careful not to touch any parts of the circuit boards with the knife.
  10. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 10 단계, 이미지 1/1
    • Remove the red, blue, and green cable from the extension connected to the sensor assembly by squeezing the tabs on the side of the connector.
  11. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 11 단계, 이미지 1/2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 11 단계, 이미지 2/2
    • Remove the red and black sleeved connector from the sensor assembly by squeezing the tab and pulling up.
  12. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 12 단계, 이미지 1/2 Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 12 단계, 이미지 2/2
  13. Hover-1 H1 Gyroscope Sensor Assemblies Replacement: 13 단계, 이미지 1/1
    • Remove the sensor assembly on the motherboard side of the hoverboard by gently lifting and pulling away from the hoverboard.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Aaron Teh
회원 가입일: 10/08/18
442 평판
안내서 2개 작성하였습니다
Cal Poly, Team S17-G6, White Fall 2018 Cal Poly, Team S17-G6, White Fall 2018 회원
CPSU-WHITE-F18S17G6
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
where can I get the replacement parts?
Rob Sayles - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 17
30일 전: 111
전체 시간: 4,844
