소개
Is one side of your Hover-1 Horizon unresponsive? This is a guide to show you how to replace the left gyroscope board, the most likely culprit to your problem. This guide requires a Phillips #2 and a Phillips #1 screwdriver.
필요한 것
Remove the two connectors on either side of the board by lifting the tab and pulling out.
Remove the connector in the middle of the board by squeezing the tab and pulling up.
다른 한 분이 해당 안내서를 완성하였습니다.
