주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hover-1 Horizon Left Gyroscope Sensor Board Replacement
필요한 것
  1. Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Base Plate: 1 단계, 이미지 2개 중 1개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Base Plate: 1 단계, 이미지 2개 중 2개
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 2 단계, 이미지 2개 중 1개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 3 단계, 이미지 3개 중 1개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 3 단계, 이미지 3개 중 2개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: 4 단계, 이미지 3개 중 1개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: 4 단계, 이미지 3개 중 2개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement, Left Gyroscope Sensor Board: 4 단계, 이미지 3개 중 3개
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
  5. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 5 단계, 이미지 2개 중 1개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
  6. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 6 단계, 이미지 3개 중 1개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 6 단계, 이미지 3개 중 2개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 6 단계, 이미지 3개 중 3개
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
  7. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 7 단계, 이미지 2개 중 1개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the middle connector by squeezing the top of the tab and pulling up.
  8. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 8 단계, 이미지 3개 중 1개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 8 단계, 이미지 3개 중 2개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
  9. Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 9 단계, 이미지 3개 중 1개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 9 단계, 이미지 3개 중 2개 Hover-1 Horizon Left Gyroscope Sensor Board Replacement: 9 단계, 이미지 3개 중 3개
    • Unclip the black connector by squeezing both sides and pulling them apart.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Casey Winans
회원 가입일: 10/08/18
324 평판
안내서 2개를 작성함
Cal Poly, Team S13-G6, White Fall 2018 Cal Poly, Team S13-G6, White Fall 2018 회원
CPSU-WHITE-F18S13G6
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 10
지난 30일: 66
전체 시간: 5,212
