주요 콘텐츠로 건너뛰기
Hover-1 Horizon Wheel/Motor Replacement
필요한 것
  1. Hover-1 Horizon Wheel/Motor Replacement, Base Plate: 1 단계, 이미지 1/2 Hover-1 Horizon Wheel/Motor Replacement, Base Plate: 1 단계, 이미지 2/2
    • Remove the six 12mm Phillips #2 screws holding the base plate.
  2. Hover-1 Horizon Wheel/Motor Replacement: 2 단계, 이미지 1/2 Hover-1 Horizon Wheel/Motor Replacement: 2 단계, 이미지 2/2
    • Remove the two 11mm Phillips #1 screws that hold the base plate to the body.
  3. Hover-1 Horizon Wheel/Motor Replacement: 3 단계, 이미지 1/3 Hover-1 Horizon Wheel/Motor Replacement: 3 단계, 이미지 2/3 Hover-1 Horizon Wheel/Motor Replacement: 3 단계, 이미지 3/3
    • Remove the base plate by lifting it up.
    • The base plate is connected to the body with wires. The wires are long enough to set the base plate to the side.
  4. Hover-1 Horizon Wheel/Motor Replacement, Left Gyroscope Sensor Board: 4 단계, 이미지 1/3 Hover-1 Horizon Wheel/Motor Replacement, Left Gyroscope Sensor Board: 4 단계, 이미지 2/3 Hover-1 Horizon Wheel/Motor Replacement, Left Gyroscope Sensor Board: 4 단계, 이미지 3/3
    • Remove the two connectors on either side of the board by lifting the tab and pulling out.
    • Remove the connector in the middle of the board by squeezing the tab and pulling up.
  5. Hover-1 Horizon Wheel/Motor Replacement: 5 단계, 이미지 1/2 Hover-1 Horizon Wheel/Motor Replacement: 5 단계, 이미지 2/2
    • Remove the four 11mm Phillips #1 screws that hold the cover on.
  6. Hover-1 Horizon Wheel/Motor Replacement: 6 단계, 이미지 1/3 Hover-1 Horizon Wheel/Motor Replacement: 6 단계, 이미지 2/3 Hover-1 Horizon Wheel/Motor Replacement: 6 단계, 이미지 3/3
    • Remove the four 11mm Phillips #1 screws that attach the gyroscope board to the mount.
    • Lift the board to reveal the connections on the bottom.
  7. Hover-1 Horizon Wheel/Motor Replacement: 7 단계, 이미지 1/2 Hover-1 Horizon Wheel/Motor Replacement: 7 단계, 이미지 2/2
    • Remove the middle connector by squeezing the top of the tab and pulling up.
  8. Hover-1 Horizon Wheel/Motor Replacement: 8 단계, 이미지 1/3 Hover-1 Horizon Wheel/Motor Replacement: 8 단계, 이미지 2/3 Hover-1 Horizon Wheel/Motor Replacement: 8 단계, 이미지 3/3
    • Remove the four 12mm Phillips #2 screws that hold the motherboard to the base.
    • Pull the motherboard away from the gyroscope by grabbing it with two hands and pulling it to the right .
  9. Hover-1 Horizon Wheel/Motor Replacement: 9 단계, 이미지 1/3 Hover-1 Horizon Wheel/Motor Replacement: 9 단계, 이미지 2/3 Hover-1 Horizon Wheel/Motor Replacement: 9 단계, 이미지 3/3
    • Unclip the black connector by squeezing both sides and pulling them apart.
  10. Hover-1 Horizon Wheel/Motor Replacement, Wheel/Motor: 10 단계, 이미지 1/3 Hover-1 Horizon Wheel/Motor Replacement, Wheel/Motor: 10 단계, 이미지 2/3 Hover-1 Horizon Wheel/Motor Replacement, Wheel/Motor: 10 단계, 이미지 3/3
    • Remove the four 30mm Hex #6 screws.
    • Lift away the silver bracket and set it to the side.
  11. Hover-1 Horizon Wheel/Motor Replacement: 11 단계, 이미지 1/3 Hover-1 Horizon Wheel/Motor Replacement: 11 단계, 이미지 2/3 Hover-1 Horizon Wheel/Motor Replacement: 11 단계, 이미지 3/3
    • Disconnect the first clip by squeezing the latch that hold the clips together while pulling apart.
    • Disconnect the second clip by squeezing the tab while pulling the clip apart.
  12. Hover-1 Horizon Wheel/Motor Replacement: 12 단계, 이미지 1/3 Hover-1 Horizon Wheel/Motor Replacement: 12 단계, 이미지 2/3 Hover-1 Horizon Wheel/Motor Replacement: 12 단계, 이미지 3/3
    • Detach the remaining three connections by pulling them apart.
  13. Hover-1 Horizon Wheel/Motor Replacement: 13 단계, 이미지 1/2 Hover-1 Horizon Wheel/Motor Replacement: 13 단계, 이미지 2/2
    • Remove the wheel by lifting it away from the base with both hands.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Casey Winans
회원 가입일: 10/08/18
324 평판
안내서 2개 작성하였습니다
Cal Poly, Team S13-G6, White Fall 2018 Cal Poly, Team S13-G6, White Fall 2018 회원
CPSU-WHITE-F18S13G6
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 16
전체 시간: 506
