메인 콘텐츠로 스킵하기
소개
Use this guide to replace the LED lights in your Hover-1 Matrix.
  1. Use screw driver to remove screws on the back of the hover board. The second image shows what the hover board would look like when the back shell is removed. Use Phillips #1 screwdriver from the 54 bit driver toolkit.
    • Use screw driver to remove screws on the back of the hover board.
    • The second image shows what the hover board would look like when the back shell is removed.
    • Use Phillips #1 screwdriver from the 54 bit driver toolkit.
  2. After the back shell is removed, you need to remove the screws on the metal layer inside.
    • After the back shell is removed, you need to remove the screws on the metal layer inside.
  3. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  4. Once the screws are removed, you will be able to separate the upper shell and the metal layer inside like in the picture.
    • Once the screws are removed, you will be able to separate the upper shell and the metal layer inside like in the picture.
  5. After the upper shell is removed, you can see a small green pad. This small green pad is the LED light.
    • After the upper shell is removed, you can see a small green pad. This small green pad is the LED light.
    • Unscrew the two screws using Phillips #1 screwdriver from the 54 bit driver toolkit, and you should be able to take this small green pad off.
    • Once you have taken it off, put on a new LED light and screw the screws back on. Now, you have successfully replaced the LED light.
결론
Jici Zhuang
회원 가입일: 2018년 10월 22일
341 평판
안내서 2개 작성하였습니다
UC Davis, Team S7-G2, Lore Fall 2018 UC Davis, Team S7-G2, Lore Fall 2018 회원
UCD-LORE-F18S7G2
3 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 37
