주요 콘텐츠로 건너뛰기
Hover-1 Matrix Pad Replacement
필요한 것
  1. Hover-1 Matrix Pad Replacement, Pad: 1 단계, 이미지 1/2 Hover-1 Matrix Pad Replacement, Pad: 1 단계, 이미지 2/2
    • Remove the screws on the back of the hoverboard using a Phillips #1 screwdriver.
    • Remove the back shell from the hoverboard.
  2. Hover-1 Matrix Pad Replacement: 2 단계, 이미지 1/1
    • Remove the screws from the metal layer inside the hoverboard using a Phillips #1 screwdriver.
  3. Hover-1 Matrix Pad Replacement: 3 단계, 이미지 1/1
    • Separate the upper shell of the hoverboard and the metal layer inside.
  4. Hover-1 Matrix Pad Replacement: 4 단계, 이미지 1/2 Hover-1 Matrix Pad Replacement: 4 단계, 이미지 2/2
    • Start by identifying the motherboard, which is the green pad shown in the picture.
    • Remove the screws on the corners of the motherboard with the Phillips #1 screwdriver and take it off.
    • There are cables attached to the motherboard so go ahead and unattach them.
  5. Hover-1 Matrix Pad Replacement: 5 단계, 이미지 1/3 Hover-1 Matrix Pad Replacement: 5 단계, 이미지 2/3 Hover-1 Matrix Pad Replacement: 5 단계, 이미지 3/3
    • Use picture 1 as a guide and move the motherboard to the other side.
    • Identify the two black rubber buttons that are shown in the second picture.
    • Remove the two rubber buttons using the Phillips #1 screwdriver.
  6. Hover-1 Matrix Pad Replacement: 6 단계, 이미지 1/1
    • Removing the rubber buttons in the previous step allows you to take the pad off.
    • Finally, take off the old pad and put on a new pad.
결론
To reassemble your device, follow these instructions starting with step number 6 and finishing with step number 1.
다른 한 분이 해당 안내서를 완성하였습니다.
Jici Zhuang
회원 가입일: 10/22/18
362 평판
안내서 2개 작성하였습니다
UC Davis, Team S7-G2, Lore Fall 2018 UC Davis, Team S7-G2, Lore Fall 2018 회원
UCD-LORE-F18S7G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 338
