주요 콘텐츠로 건너뛰기
Hover-1 Matrix Right Gyroscope Sensor Board Replacement
필요한 것
  1. Hover-1 Matrix Right Gyroscope Sensor Board Replacement, Right Gyroscope Sensor Board: 1 단계, 이미지 1/3 Hover-1 Matrix Right Gyroscope Sensor Board Replacement, Right Gyroscope Sensor Board: 1 단계, 이미지 2/3 Hover-1 Matrix Right Gyroscope Sensor Board Replacement, Right Gyroscope Sensor Board: 1 단계, 이미지 3/3
    • Locate and use the screw driver and 54 bit as shown in figure 3. Use screw driver to remove screws on the back of the hover board as shown in figure 1. Remove the back shell as shown in figure 2.
  2. Hover-1 Matrix Right Gyroscope Sensor Board Replacement: 2 단계, 이미지 1/2 Hover-1 Matrix Right Gyroscope Sensor Board Replacement: 2 단계, 이미지 2/2
    • Locate green electric boards at both ends of the hover board. These green boards are the gyroscopes. Use the screw driver to remove the screws from the corners of the green boards as shown in figure 1.
결론
Qingxi Liu
회원 가입일: 10/22/18
85 평판
안내서 1개 작성함
UC Davis, Team S7-G2, Lore Fall 2018 UC Davis, Team S7-G2, Lore Fall 2018 회원
UCD-LORE-F18S7G2
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 419
