주요 콘텐츠로 건너뛰기
Hover-1 Maverick Battery Replacement
필요한 것
  1. Hover-1 Maverick Battery Replacement, Battery: 1 단계, 이미지 1/2 Hover-1 Maverick Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Remove the shell.
  2. Hover-1 Maverick Battery Replacement: 2 단계, 이미지 1/3 Hover-1 Maverick Battery Replacement: 2 단계, 이미지 2/3 Hover-1 Maverick Battery Replacement: 2 단계, 이미지 3/3
    • Remove the four 8mm Phillips #1 screws holding down the black plastic casing.
    • Lift off the black plastic retaining bracket.
  3. Hover-1 Maverick Battery Replacement: 3 단계, 이미지 1/2 Hover-1 Maverick Battery Replacement: 3 단계, 이미지 2/2
    • Pull the battery upward lightly to remove from the device.
    • The battery is secured to the device with adhesive tape.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Piper Feldman
회원 가입일: 01/23/20
409 평판
안내서 4개 작성하였습니다
Cal Poly, Team S2-G2, White Winter 2020 Cal Poly, Team S2-G2, White Winter 2020 회원
CPSU-WHITE-W20S2G2
2 회원들
안내서 4개 작성하였습니다
댓글 2개
What voltage should the battery put out? Mines is 30v, charger is green at the wall but still the board won’t turn on
Barry Rogers - 답글
Where can I find that same battery i cant find one
Toad Blue - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 14
30일 전: 44
전체 시간: 2,805
