주요 콘텐츠로 건너뛰기
Hover-1 Maverick Central Bearing Replacement
필요한 것
  1. Hover-1 Maverick Central Bearing Replacement, Central Bearing: 1 단계, 이미지 1/3 Hover-1 Maverick Central Bearing Replacement, Central Bearing: 1 단계, 이미지 2/3 Hover-1 Maverick Central Bearing Replacement, Central Bearing: 1 단계, 이미지 3/3
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Remove the shell from the hoverboard. The central bearing is located in the center.
  2. Hover-1 Maverick Central Bearing Replacement: 2 단계, 이미지 1/1
    • Unscrew the eight 16mm Phillips #1 screws holding the central bearing in place.
  3. Hover-1 Maverick Central Bearing Replacement: 3 단계, 이미지 1/2 Hover-1 Maverick Central Bearing Replacement: 3 단계, 이미지 2/2
    • Unplug the wires that run through the central bearing. There is a black and yellow one that attaches to the battery and a set of white ones that attach to the motherboard.
    • Run these wires out through the other end of the central bearing.
  4. Hover-1 Maverick Central Bearing Replacement: 4 단계, 이미지 1/2 Hover-1 Maverick Central Bearing Replacement: 4 단계, 이미지 2/2
    • One side of the bearing is easy to pop out with your hands.
    • The other side of the bearing has wiring for the LED light running under it, so it cannot be pulled out with your hands. To get leverage, carefully use the metal spudger to wedge out this other side.
  5. Hover-1 Maverick Central Bearing Replacement: 5 단계, 이미지 1/1
    • Take the central bearing out of the board.
결론
Piper Feldman
회원 가입일: 01/23/20
409 평판
안내서 4개 작성하였습니다
Cal Poly, Team S2-G2, White Winter 2020 Cal Poly, Team S2-G2, White Winter 2020 회원
CPSU-WHITE-W20S2G2
2 회원들
안내서 4개 작성하였습니다
댓글 한 개
Where do I buy this central bearing of hover 1?
Sinan Sönmez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 6
전체 시간: 471
