주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide for the Hover-1 Maverick guides users in replacing the foot mats on their device. The foot mats are crucial in allowing the hoverboard to balance and communicate movement to the rest of the device. A symptom of having faulty foot mats would be if the hoverboard is unable to balance.
부품
지정된 부품이 없습니다.
  1. Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard. Open the shell. There is one motherboard on each side of the device located near the wheels.
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
  2. Disconnect the battery to prevent any electrical currents from coming through the wires. Disconnect the battery to prevent any electrical currents from coming through the wires.
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Squeeze and pull on the wires to detach them from the motherboard. Squeeze and pull on the wires to detach them from the motherboard.
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Remove the four 8mm Phillips #1 screws. Remove the motherboard from the device.
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
  5. Remove six 1mm Phillips #1 screws. Remove six 1mm Phillips #1 screws.
    • Remove six 1mm Phillips #1 screws.
  6. Remove the foot mats from the top of the board, which is facing down right now.
    • Remove the foot mats from the top of the board, which is facing down right now.
결론
Piper Feldman
회원 가입일: 2020년 01월 23일
391 평판
안내서 4개 작성하였습니다
Cal Poly, Team S2-G2, White Winter 2020 Cal Poly, Team S2-G2, White Winter 2020 회원
CPSU-WHITE-W20S2G2
2 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 7
전체 시간: 77
