주요 콘텐츠로 건너뛰기
Hover-1 Maverick Motherboard Replacement
필요한 것
  1. Hover-1 Maverick Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Hover-1 Maverick Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Hover-1 Maverick Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
  2. Hover-1 Maverick Motherboard Replacement: 2 단계, 이미지 1/2 Hover-1 Maverick Motherboard Replacement: 2 단계, 이미지 2/2
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Hover-1 Maverick Motherboard Replacement: 3 단계, 이미지 1/2 Hover-1 Maverick Motherboard Replacement: 3 단계, 이미지 2/2
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Hover-1 Maverick Motherboard Replacement: 4 단계, 이미지 1/2 Hover-1 Maverick Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Cassandra Aarrestad
회원 가입일: 01/23/20
627 평판
안내서 4개 작성하였습니다
Cal Poly, Team S7-G2, Paton Spring 2020 Cal Poly, Team S7-G2, Paton Spring 2020 회원
CPSU-PATON-S20S7G2
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 26
전체 시간: 2,278
