주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide for the Hover-1 Maverick guides users in replacing the motor in their device. The motor is crucial within the hoverboard. It converts energy in order to allow the device to move. Symptoms of having a faulty motor include the device not being able to move or it has flashing lights. Users will need to disconnect the battery along with wires in order to replace the motor.
부품
지정된 부품이 없습니다.
  1. Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard. Open the shell. There is one motherboard on each side of the device located near the wheels.
    • Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
    • Open the shell.
    • There is one motherboard on each side of the device located near the wheels.
  2. Disconnect the battery to prevent any electrical currents from coming through the wires. Disconnect the battery to prevent any electrical currents from coming through the wires.
    • Disconnect the battery to prevent any electrical currents from coming through the wires.
  3. Squeeze and pull on the wires to detach them from the motherboard. Squeeze and pull on the wires to detach them from the motherboard.
    • Squeeze and pull on the wires to detach them from the motherboard.
  4. Remove the four 8mm Phillips #1 screws. Remove the motherboard from the device.
    • Remove the four 8mm Phillips #1 screws.
    • Remove the motherboard from the device.
    • Repeat for the other motherboard.
  5. After the motherboard is removed from either side, remove the four 15 mm hex screws with a 5mm Allen wrench. Remove the metal covering from over the motor.
    • After the motherboard is removed from either side, remove the four 15 mm hex screws with a 5mm Allen wrench.
    • Remove the metal covering from over the motor.
  6. The motor is attached to the wheel, so in order to remove the motor, you must take out the entire wheel.
    • The motor is attached to the wheel, so in order to remove the motor, you must take out the entire wheel.
결론
Piper Feldman
회원 가입일: 2020년 01월 23일
391 평판
안내서 4개 작성하였습니다
Cal Poly, Team S2-G2, White Winter 2020 Cal Poly, Team S2-G2, White Winter 2020 회원
CPSU-WHITE-W20S2G2
2 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 13
전체 시간: 86
