주요 콘텐츠로 건너뛰기
Hover-1 Nomad Charging Port Replacement
필요한 것
  1. Hover-1 Nomad Charging Port Replacement, Outer Shell: 1 단계, 이미지 1/3 Hover-1 Nomad Charging Port Replacement, Outer Shell: 1 단계, 이미지 2/3 Hover-1 Nomad Charging Port Replacement, Outer Shell: 1 단계, 이미지 3/3
    • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
    • Remove the following twenty screws by rotating the screwdriver counterclockwise:
    • Eight 16.2mm Phillips #2 screws
    • Eight 15mm Phillips #2 screws
    • Four 19.1mm Phillips #2 screws
    • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
    • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
  2. Hover-1 Nomad Charging Port Replacement: 2 단계, 이미지 1/3 Hover-1 Nomad Charging Port Replacement: 2 단계, 이미지 2/3 Hover-1 Nomad Charging Port Replacement: 2 단계, 이미지 3/3
    • Use a nylon spudger to pry the metal handle away from the outer shell.
    • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
    • Lift the hoverboard off the metal handle.
    • Repeat for the handle on the other side of the hoverboard.
  3. Hover-1 Nomad Charging Port Replacement: 3 단계, 이미지 1/1
    • Lift the plastic cover on each side up and away from the device.
    • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
  4. Hover-1 Nomad Charging Port Replacement: 4 단계, 이미지 1/2 Hover-1 Nomad Charging Port Replacement: 4 단계, 이미지 2/2
    • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
    • Charging port wires
    • Speaker assembly wires
    • Power button wires
    • Headlight wires
    • Only the headlight wires need to be disconnected from the other circuit board.
    • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
  5. Hover-1 Nomad Charging Port Replacement, Charging Port: 5 단계, 이미지 1/2 Hover-1 Nomad Charging Port Replacement, Charging Port: 5 단계, 이미지 2/2
    • Peel off the glue around the charging port.
    • Unscrew the hexagonal nut around the charging port by rotating the nut counterclockwise with a pair of pliers.
  6. Hover-1 Nomad Charging Port Replacement: 6 단계, 이미지 1/1
    • Feed the wire and connector through the removed nut and pull the charging port out through the hole in the outer casing.
    • Pulling the connector through the nut is a tight fit. Try turning the plug sideways to fit the connector through the nut.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Samuel Frazee
회원 가입일: 10/08/18
1,015 평판
안내서 7개 작성하였습니다
Cal Poly, Team S15-G1, White Fall 2018 Cal Poly, Team S15-G1, White Fall 2018 회원
CPSU-WHITE-F18S15G1
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 390
