주요 콘텐츠로 건너뛰기
Hover-1 Rally Acceleration Lever Replacement
필요한 것
  1. Hover-1 Rally Acceleration Lever Replacement, Acceleration Lever: 1 단계, 이미지 1/1
    • Remove one 4 mm Phillips #1 screw located directly above the acceleration lever.
  2. Hover-1 Rally Acceleration Lever Replacement: 2 단계, 이미지 1/2 Hover-1 Rally Acceleration Lever Replacement: 2 단계, 이미지 2/2
    • Turn the right handle grip counterclockwise.
    • The right handle will disconnect from the handlebar, exposing the acceleration lever.
  3. Hover-1 Rally Acceleration Lever Replacement: 3 단계, 이미지 1/1
    • Remove four 2 mm Phillips #00 screws located on the acceleration throttle.
  4. Hover-1 Rally Acceleration Lever Replacement: 4 단계, 이미지 1/1
    • Pull the acceleration lever off of the handle.
    • The acceleration lever sits perpendicular to the handle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Van Schneider
회원 가입일: 02/10/20
112 평판
안내서 1개 작성함
Cal Poly, Team S7-G2, Regan Winter 2020 Cal Poly, Team S7-G2, Regan Winter 2020 회원
CPSU-REGAN-W20S7G2
6 회원들
안내서 7개 작성하였습니다
댓글 4개
Where did you find the lever?
Jaimi Erwin - 답글
See comment below. Swap out your power throttle with the brake lever. Or reach out to Hover-1 for spare parts.
Chris Serio -
Thank you Mr Fix It Man. I haven't used my scooter in months and never tried to find parts. Swapped my throttle out with my brake lever and we're good to go hehe
Chris Serio - 답글
The throttle lever on my daughter’s scooter broke off and I have been unable to get through to Hover for replacement parts (both online and tried to call). Do you know of any universal levers that would work? Or where I could locate a lever? Bought this for my daughter to get to college classes and this is her first week and it broke (out of 90 day warranty, of course.)
Sharon Kolson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 31
전체 시간: 2,043
