주요 콘텐츠로 건너뛰기
Hover-1 Superstar Battery Replacement
필요한 것
  1. Hover-1 Superstar Battery Replacement, Bottom Case: 1 단계, 이미지 1/3 Hover-1 Superstar Battery Replacement, Bottom Case: 1 단계, 이미지 2/3 Hover-1 Superstar Battery Replacement, Bottom Case: 1 단계, 이미지 3/3
    • Flip your Hover-1 Superstar device upside down.
    • Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
    • Remove the bottom case. Be careful of the connector holding the case and the device together.
  2. Hover-1 Superstar Battery Replacement: 2 단계, 이미지 1/1
    • Locate the cable connected to the front lights.
    • Pull apart the wires until the black clip separates.
  3. Hover-1 Superstar Battery Replacement, Battery: 3 단계, 이미지 1/2 Hover-1 Superstar Battery Replacement, Battery: 3 단계, 이미지 2/2
    • Locate the four 14mm screws securing the battery bracket.
    • Remove the screws with a Phillips #1 screwdriver.
  4. Hover-1 Superstar Battery Replacement: 4 단계, 이미지 1/1
    • Pull and disconnect the cable connector that is connected to the battery.
  5. Hover-1 Superstar Battery Replacement: 5 단계, 이미지 1/1
    • Pull on the battery until it separates from the hover board. You may need to use some force.
    • Be sure the battery is disconnected before performing this step to avoid electrocution.
    • There will be a loud crack when the battery is removed. This is normal due to the adhesive on the back of the battery.
    • Pull the battery out of the hoverboard. Move wires away from the battery if necessary.
결론
Keegan
회원 가입일: 10/04/18
632 평판
안내서 5개 작성하였습니다
댓글 한 개
How do u get a 25.2v battery at for my hover-1
chivitbprince Boonking - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 20
전체 시간: 1,643
