소개
In order to access the internal components of the Hover-1 Superstar, the bottom case must first be unscrewed and removed. This guide will explain the process of removing the bottom case from the Hover-1 Superstar.
필요한 것
Flip your Hover-1 Superstar device upside down.
Using a Phillips #1 screwdriver, remove all twenty of the 18mm screws holding the case onto the device.
Remove the bottom case. Be careful of the connector holding the case and the device together.
거의 끝나갑니다!
결론
